Bookshelf Speakers which ones????
Discussion in 'Archived Threads 2001-2004' started by Ryan_SS, Feb 13, 2002.
  1. Ryan_SS
    Ryan_SS Extra
    May 21, 2001
    17
    Ok I have been ok'd for a new set of speakers, but I can only get bookshelf size, WAF and all, so I am looking at a couple of options. Comments on these systems, or suggestions.
    1 2.1 Divas
    2 Paradigm Mini-monitors
    3 PSB Mini's
    4 Polk 35 or 55 series
    any comments or other suggestions
    I am looking to keep it under 1300 thank you
    Ryan
  2. Bob_A
    Bob_A Supporting Actor
    Jul 30, 2000
    876
  3. Paul_Fisher
    Paul_Fisher Screenwriter
    Dec 27, 2001
    1,219
    I'm biased to the Mini Monitor's because thats what I have and I love them. I'm sure alot of other people will second this. Just my .02 [​IMG]
  4. EricHaas
    EricHaas Supporting Actor
    Dec 25, 2001
    667
    $1300 for what? A pair of bookshelf speakers, a 5 piece set, or a 6 piece set (with subwoofer)? If the $1300 is just for a pair of bookshelves, you can get some very high end stuff.
  5. BryanZ
    BryanZ Screenwriter
    Dec 18, 2000
    1,213
  6. Bobby T
    Bobby T Supporting Actor
    Mar 13, 2001
    583
    Klipsch Synergy series
  7. Ryan_SS
    Ryan_SS Extra
    May 21, 2001
    17
    I am sorry the way I worded it was confusing I am looking to keep it under 1300 for 2 pair plus a center channel sorry for the confusion
  8. Dan_Jones
    Dan_Jones Stunt Coordinator
    Dec 1, 2001
    120
    I'm thinking Axiom M22's (~$400 a pair) or Axiom M3's (~$275 a pair)
    Their website: www.axiomaudio.com
    Some reviews:
    M22 @ SoundStage
    M3 @ SoundStage followup
    M3 @ Masters on Audio
    M3 @ Good Sound
    M3 @ SoundStage
    Both can be found cheaper via www.audioshop.on.ca
    That's my thoughts!
  9. Bob_A
    Jul 30, 2000
    876
    In that case, how about 3 PowerMonitor500's across the front stage...should be nice.
  10. EricHaas
    Dec 25, 2001
    667
    My recommendation:
    Paradigm
    1 pair Monitor Minis ($300)
    cc-370 center ($325)
    1 pair adp-370 dipole surrounds ($550)
    In the alternative, if you prefer monopoles or just want to save money, a second pair of minis will be fine for surrounds. You could even go down to Titans ($200) for surrounds, and save even more money for a subwoofer or something else. Any of these options will sound terrific for the money.
    Also in your price range add to your list Divas by Swans (www.av123.com - look at the 2.1's) and HTD lvl 3 (www.hometheaterdirect.com - combo X). These are both online only sellers, and both are supposed to sound much better than they cost. I mentioned the Swans in particular because you indicated that WAF is an issue here. The Swans look fantastic, and have somewhat of a cult following online, much like Paradigms do.
    Edit: I just noticed the Divas are on your original list.
  11. ThomasL
    ThomasL Supporting Actor
    Mar 13, 2001
    963
    Ryan, do you have any size constraints on the bookshelves? height, width, depth? You mentioned the WAF rating [​IMG] so I figured this was a good question to ask since bookshelves' sizes can range quite a bit.
    cheers,
    --tom
  12. Ariel
    Ariel Stunt Coordinator
    May 13, 2001
    109
    $1,300 for 3 speakers, try the paradigm studio20 + reference cc.
  13. Ryan_SS
    Ryan_SS Extra
    May 21, 2001
    17
    As far as size goes, I am going to play dumb on that issue, ie you said bookshelf but didn't mention how big, might get into some trouble but ohhh well. I am leaning heavily toward the swans I think the look would help ease the WAF factor.
  14. EricHaas
    Dec 25, 2001
    667
    [​IMG] Good call on the Divas if that's the way you go. I've never heard them, but based on reviews I doubt you will be disappointed with the sound. You might even be blown away. I have to admit that ever since I picked up my Paradigm Reference speakers (in black laminate), I have been secretly jonesing for the Divas. I cannot fault the Paradigms for sound at all. They're fantasic. But something about the look of the Divas. Maybe I'm more superficial than I thought. Nah.
