Marcus Lewis
- Oct 27, 2001
If the bookshelf speakers in a 5.1 environment are always going to be set to small with your sub of choice (in my case a 16-46CS+) handling everything down low; how important is low end extension on the bookshelf speakers?
Is it a factor at all? Isthere really any point with going with a bookshelf speaker that plays well down to 50hz vs a cheaper model that has the same upper frequency range but only goes down to 80hz? Or is there some hidden advantage I am unaware of of having a bookshelf with more range?
Thanks in advance if someone can clear this up for me ...
