Bookshelf Speaker Placement
Discussion in 'Archived Threads 2001-2004' started by Ten_Smith, Mar 14, 2002.
  1. Ten_Smith
    Ten_Smith Stunt Coordinator
    Dec 21, 2001
    76
    I am planning on putting my new bookshelf speakers (AR 2602s) in a solid wood bookshelf. Do I need to put felt or some other insulator between them and the wood, or can I just chuck 'em in there?
  2. Paul_Fisher
    Paul_Fisher Screenwriter
    Dec 27, 2001
    1,219
    I would use some of those little rubber stick on things. If you put them directly on the shelf they will have a tendency to vibrate a little and move. Try to find some of those rubber things and stick 4 on the bottom corners of the speakers. Hope this helps.
  3. Ten_Smith
    Dec 21, 2001
    76
    thanx, I'll do that.
