Martice
- Jan 20, 2001
What size cabinet are you using Brian?
The fact that they are not as efficient as most speakers means you should have capable amplification to really get the best out of them.
The website states sensitivity at 88db for the AV1's and 91db for the AV1+'s, which I consider to be fairly efficient. Are these specs over-optimistic? I was considering these speakers, but I would only be pushing them with a 60wpc H/K 310 and now am not sure if that would be enough power.
Am I correct in assuming that, when placing the center, vertical is preferable to horizontal? Also, does the off-set tweeter design mitigate any performance disadvantage to horizontal placement and to what degree?
Chris,
Vertical is always preferable. I'm going to try both ways to see if I hear any major differences. As far as any possible disadvantages with the offset tweeter, you'd have to ask Danny about that. I build 'em; I don't design 'em!
Guy,
I think you'd be fine driving the AV-1's with the H/K receiver. A rating of 88dB is fairly average. I can't say for sure if you could run the AV-1+'s with your receiver. These are rated at 4 ohms so you'd want to make sure your receiver can handle it.
Brian
I'm running 88dB Paradox 1s (similar to the AV1, different tweeter) with 8W tube amps in a 20x15 room, and the third position on my preamp's volume control is too loud for me. I use these for music only, and normally listen at around 80something dB, so your requirements may be different.
