Pete Battista
OK... I just got the TV Series Booker (spin-off of 21 Jump Street) And I must say I absolutely despise the case they used. It is one I personally never seen before.. and hopefully will never see again. Granted this set is very cheap (I paid $9.17 for the set of 20 episodes)... but they should have done better on the case then what they did!
When you first get it you see what looks to be a normal (albeit wide) Keep case...
But when you open it you find 4 envelops (1 per disc) clipped into the case...
As you can see (I know barely... quick photos not my best work)... the envelopes is what clips into the the case instead of the DVDs on hubs. So if anything happens to the envelopes then the main case is not of much good. I know... how expensive could cd envelopes be? I am sure they are cheap... but I have never seen any in my area to buy them... plus I would prefer to have black ones to match the rest of the set... which I am sure will be much harder to find.
But that really not the point I am making... was such a choice really necessary? I personally would rather have something much more standard.
What do you think?
- Like the setup?
- It is ridiculous?
- Something else?
What do you think?
- Like the setup?
- It is ridiculous?
- Something else?
