Blurry Image
Discussion in 'Beginners, General Questions' started by Eric Waldman, Jul 20, 2004.
  1. Eric Waldman
    Eric Waldman Auditioning
    Nov 25, 2003
    3
    My friend just bought a 56" Sony TV and I was disgusted at how bad non Hi Definition programming looks. It's all blurry, full of artifacts and im dissapointed with it.
    I'm planning on buying a Hitachi 46W500 and I don't want that happening to me, is their any way to increase the resolution of the images without killing the quality? I'm not sure if I am going to be able to get the HDTV receiver from StarChoice right away or an HDTV DVD Player so I want to have some acceptable IQ for the meanwhile.
    Thanks in advance.
  2. StephenHa
    StephenHa Second Unit
    Sep 28, 2003
    364
    the big hd sets have a problem with the low quality sd broadcasts, most of what your seeing is not the tv, it's the broadcast that was designed for a 19" tv sometimes doing a calibration makes it better, also the choice of connections will effect it greatly use the best connection possible, the hitachi does pretty well on sd stuff, I've also never liked sony'd big screen tv picture (could be since they are using someone elses tubes in them)
  3. Jack Briggs
    Jun 3, 1999
    16,738
    129
    What Stephen said. And the bigger the display, the more apparent the hideous flaws and artifacting in most NTSC cablecasts.
  4. Eric Waldman
    Nov 25, 2003
    3
    I still don't see why it should be this bad, I resize images in photoshop all the time and it is fine.
    IMAX resized images as well and there is no apparent loss in quality, is it just that it is too expensive to do this for personal use or something?
  5. StephenHa
    Sep 28, 2003
    364
    take an image that's 100x100 and blow it up to 1020x480 and you'll get an idea. What your seeing are defects that are there just magnified so you actually see tehm
  6. Eric Waldman
    Nov 25, 2003
    3
    I resized this image img48.photobucket.com/albums/v146/Enrickey/1080bg.jpg from 640x480 (NTSC resolution) to 1440x1080, while a lot of the quality is lost, I can honestly say that the quality is much better then my friend's TV did.
