Blurry Image with Toshiba set
Discussion in 'Displays' started by Antonio_B, Oct 2, 2005.
  1. Antonio_B
    Antonio_B Stunt Coordinator
    Oct 18, 2002
    187
    Recently,i noticed that my Toshiba 57HDX82 has given me a blurry and a not very sharp picture.
    Once i try to see a DVD movie i notice some grain on the image.I am thinking maybe this could be some dirt in the DVD player.Could that be a factor for not having a crisp picture with DVD's?
    With Cable it hasn't really changed.
  2. Tim Jin
    Tim Jin Supporting Actor
    Jan 12, 2003
    529
    It could also be your CRT guns are collecting dust and needs to be clean.
  3. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    Greetings
    Cleaning
    And double check the electronic focus and mechanical focus ...
    Regards
  4. Antonio_B
    Oct 18, 2002
    187
    That means i have to clean the lens?Can i do that by myself?
  5. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    Greetings
    Depends on if you have an extended warranty.
    Cleaning is easier than changing the oil on your car ...
    Regards
  6. Antonio_B
    Oct 18, 2002
    187
    Do you have any good tutorial about how to clean the lens of your RPTV?
  7. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    Greetings
    take speaker grill off ... (take off ground wire)
    unscrew bottom of the screen frame ...
    unscrew front control panel
    unclip flash focus wires
    life screen up and off ...
    now clean the crts ... (common sense)
    close it up ...
    REgards
  8. Jerome Grate
    Jerome Grate Cinematographer
    May 23, 1999
    2,984
    6
    110
    Does the same procedure apply for the Sony KP51WS520 ?
  9. Gregg Loewen
    Gregg Loewen Video Standards Instructor, THX Ltd.
    Insider
    Nov 9, 1999
    6,374
    32
    6,610
    New England
    Gregg Loewen
    no on the Sony
    For Sonys:
    remove the rear access panel and then clean away!!
