blu-ray questions (1 Viewer)
redbandit
Bob
hello
i want to get a blu-ray player. my tv does not have an hdmi hookup. only component video and can only do 1080i. blu-ray is 1080p what will this do to the picture? can i use the component video hookups from a video switch that i use now for xbox 360 with the hd player and my hd satellite? i use my receiver yamaha htr 5940 as it is now just for the sound no audio goes to the tv. what do i need to get to make this work? will it work?
Jeff Gatie
Blu-ray players will output in 1080i for Blu-ray disks as long as the disk is authored for it, which is, as far as I know, all of them. You won't get upconversion of standard DVD via component, but you will get 1080i from BD's.
redbandit
Bob
i saw some kind of adapter on ebay that converts hdmi to component video is this something worth looking into?
Robert_J
Mississippi
Get a Blu Ray player that already has component video outputs. Why would you want to add an adapter to the mix?
-Robert
bpickell
Brian
Isn't there a problem with running HD content over component? I thought I read somewhere that it has to go through HDMI because of that stupid HDCP copy protection scheme, or something like that.
Jeff Gatie
Component is limited to 1080i/720p for Blu-ray, and the players will not upconvert regular DVD to HD over component because of copy protection.
Greg_R
Portland, OR
Greg
With a quality adapter you get upconversion capabilities + 1080p to your analog display (assuming your device supports it). This is a great option for those of us with older CRT projectors.
seedybrick
ken
ok so if you have a comp connection and are only getting 1080i wouldn't your native 1080p television finish that upconversion to 1080p anyhoo?
Jeff Gatie
If you have a 1080p TV, I would assume it has HDMI and the subject doesn't apply. We are talking about CRT based, component only TV's.
Cabby
