Colin Jacobson
- Apr 19, 2000
I use my "backup" BD player almost solely to copy audio commentaries onto cassette so I can listen to them elsewhere.
It's worked fine for years, but when I went to use it the other day, I got an image with a massive pink/purple tint. I also got no audio from the TV itself.
I thought this might've been my TV acting up, so I turned off the set and turned it back on, which has cured similar glitches.
Nope. Still the same.
I thought it might've been an HDMI cable gone bad, so I used a different cable that also went to a different input on the same TV.
No change.
The BD player still puts out audio via the RCAs, so I continue to be able to record commentaries, and it plays back movies fine other than the color and the lack of audio to the TV.
Any thoughts about this? Maybe the player just crapped out in an odd way and it's time for a new one?
No change.
