Blu-Ray on 720p Projector? (1 Viewer)
chris.big.money
Chris Walter
No response in the other forum, so i thought i'd try this one. If i got a Panasonic PT-AX200U and paired it with a PS3, would i get a scaled 720p image? Or is it 1080p only?
Martino
Santa Clara, CA
Martin O.
The projector produces a 720P image from whatever source you throw at it - that is all it can produce - so it will scale down the 1080p comming from your PS3...
Doug_H
Chris
PS3 will give you a great picture on that PJ. Try both the 720p and 1080i/p settings on the PS3 and decide which is better.
eathree
