Only if the player uses Darbee or some other kind of artificial video processing / enhancement.Hey Clinton, yes, I’m doing 1:1 rips. I guess I was wondering if the blu ray players might sweeten the image a bit.
One final warning: you shouldn’t even consider extenders that don’t use 802.11ac. Old 802.11n extenders are cheaper, but they will significantly decrease the speed of all devices on your Wi-Fi when the extender is running, and they will provide less than half of the base router’s speed to devices connected by Wi-Fi to the extender itself.
[URL='https://wclink.co/link/25550/0/4/73450/?merchant=Walmart']P-Link’s RE200
[/URL]isn’t the fastest Wi-Fi extender on paper, but it boasts two massive advantages over its competitors: it’s dirt cheap, and it never made the Wi-Fi worse in any of our tests. It's also compact, plugs directly into a power outlet, and offers a 100 Mbps wired Ethernet port for nearby devices. Our powerline networking pick is better, but if your house’s wiring is older or you don’t want to spend $120, the RE200 is the clear winner
I found that the Plex program couldn’t deinterlace but that Infuse did. Once I switched to Infuse for playback, no lines. Still the same DVD rip.
Information like that makes me one step closer to getting an Apple TV for streaming purposes. My goal is to have all my DVDs on a NAS since my shelf space is filled with Blu-rays and it's a pain to dig out a DVD to watch.
Short answer: a single router is relying on a powerful radio to send a strong enough signal to overcome transmission losses through walls and distance. A mesh is a relay system to send the signal around obstacles and reduce absolute distance from local radio to get better performance.By the way, about the MESH WiFi routers, a friend showed me his Google MESH set up at his house. He says it works great. And Dave, I went to the Wirecutter site and found reviews of the Eero Pro MESH. It’s a bit pricey, but it’s on my list now to consider. I guess you can’t change the laws of physics, as I wondered about how a more modern WiFi router can be better then my older Apple Airport Extreme in terms of how the 5ghz and 2.4 ghz frequencies has the ability to penetrate the walls and glass in my house. I’m going to read up on how the MESH works to understand it better, but if the 5ghz frequencies drop off in range so fast in my house with the AirPort Extreme, I wonder how the MESH units can talk to the other wireless units and also have the higher brand width then a single router can do. Anyway, I’ll be reading up more on it. Hopefully I can make a good choice.
