1. Cees Alons
    Cees Alons Moderator
    Jul 31, 1997
    19,412
    312
    9,110
    Cees Alons
    John,
    You could disconnect the amp from the driver (remove at least one lead - and if you remove both, remember which one was connected to which terminal), then remove any input wires from the amp as well as the power connection and connect the driver to another amp (e.g. the Center or L or R of your system). Personally, I would feel more comfortable if I knew the impedance of the sub's driver, to make sure it matches the amp you're connecting (more or less).
    This way you could find out if the speaker driver is OK. A problem might be to close the box if you have to feed that extra set of wires through, so don't try to play it too loud - for more than one reason, BTW.
    Good luck.
    Cees
    PS Did the "farting noise" come from the speaker itself, or could it have been the port?
    C.
  2. Marc H
    Marc H Second Unit
    Aug 22, 2001
    497
    Also inspect the surround around the woofer cone closely in case it's coming away from the frame and 'passing wind'.
  3. I believe that everything is 4 ohm. I know the sub is. Anyway I have already disconnected both of the leads to the cone and will attempt to do it on almost minimal volume to see if it makes the sound.
    The noise was coming most definitely from the cone and not the port. I assume by port you mean the rear hole.
  4. Dave_vega
    Dave_vega Stunt Coordinator
    Dec 16, 2002
    168
    try pushing very lightly on the cone itself..make like a spider with your hand and push equally around the cone..if it makes a scratching noise then the sub is blown..
  5. GrahamT
    GrahamT Supporting Actor
    Sep 13, 2003
    556
    Air leaking around the driver gasket can make a loud farting noise.
