Blown Shiva EBS
Discussion in 'Home Theater Projects' started by Russell R, Feb 19, 2005.
  1. Russell R
    Russell R Stunt Coordinator
    Feb 20, 2000
    69
    Hello,
    I watched Alien vs. Predatur last night at my normal reference level. The shiva is toast. The enclosure is an EBS design tuned to 18.1hz. Any ideas on what to do next? Would an Adire Alignment be better at protecting the driver? I am using a Parts Express plate amp with a Behringer FBD. I had no problems with LOTR 1-3 or anything else for that matter. I wonder what frequency and amplitude made this happen.
    Russ
  2. RobertFirment
    Dec 28, 2004
    23
    My Shiva blew out too. I went with the Atlas and have been very happy.
  3. Russell R
    Feb 20, 2000
    69
    What is the Atlas? Luckily, I have an extra Shiva in a box for a backup.
  4. stephanX
    stephanX Stunt Coordinator
    Nov 23, 2004
    116
    did you hear any clicking or bottoming? which part of the movie did it blow in? you must have been clipping or something becuase 250 sure wont blow a shiva.
  5. RandyMathis
    RandyMathis Stunt Coordinator
    Jan 19, 2003
    94
  6. Russell R
    Feb 20, 2000
    69
    Yes, the spider has separated from the basket. I wonder if this can be glued back? I am not sure if the coil is shot. I can look at this later. I replaced the driver with a new one and all is good.
    The last major boom scene in AVP caused this. I believe that the BFD may have gone into some sort of clipping or the driver was pushed too hard at some very low freq. I readjusted the EQ and levels.
    I need to build a second EBS to give me more headroom.
  7. Russell R
    Feb 20, 2000
    69
    What type of enclosure/setup are you using with the Atlas? I checked out the website and it looks promising for the next sub. Anyone else using the Atlas?
  8. Randy Noel
    Randy Noel Stunt Coordinator
    Mar 28, 2002
    101
    I'm using the Atlas 15 in an Adire Alignment ported enclosure, 214l, and couldn't be happier. Terrific performance!
  9. Allen Ross
    Allen Ross Supporting Actor
    Sep 30, 2002
    819
    if you modeled it, what kind of time delay are you seeing around the Fs? of your AA 214L
  10. Russell R
    Feb 20, 2000
    69
    I am going to model the 12" in an EBS setup.
  11. steve all
    steve all Extra
    Oct 31, 2004
    16
    i'm running an atlas 12 in a 142.5L shiva EBS enclosure and it does a great job! [​IMG] verry clean tight, and musical bass i'm tuned to about 20hz.
  12. Russell R
    Feb 20, 2000
    69
    Thanks. I will pick one up.
  13. john bourne
    john bourne Extra
    Mar 17, 2004
    24
    How old is your Shiva? I had one do the same thing - spider separated from the basket and Adire sent a replacement under warranty. If is is out of warranty it is still worth a call to Adire as it sounds like this might be a manufacturing defect as it has affected several member's drivers. Good luck.
