Rick Westfall
- Dec 8, 1998
I have a blown amp (as you know from the subject line). PSB only replaces...doesn't repair. Any suggestions on a mono amp to power my sub?
Rick
Rick
I think I may go the exact same route you went. Anyway you could describe where the four power transistors are that you replaced and where you were able to pick replacement ones up at? That would be a huge help for me, ThanksOriginally Posted by Neil Joseph
Well wadaya know! I had posted here about a year ago. My Subsonic 6 kept on blowing fuses. Mind you, I had opened it up, removed the stuffing, and over stuffed :b with new stuffing. My theory is that the amp did not have sufficient cooling space after my blunder. Anyway, I traced the problem to a small power supply but PSB was not going to sell just the power supply. The whole amp cost aroung $500 at the time. I decided to replace all 4 power transistors on the power supply board and that fixed it up.
What is the problem with yours? You did check the fuse, right?
