Mark E J
- Oct 26, 2000
I believe Charles De Lauzirika has stated before on some thread that if it was up to Ridley Scott you would have multiple versions of BR. But unfortunately it's not up to him. So I guess those specs are what Mr. Scott wants, but it it'll be up to WB wether or not you'll see it.
the only reason I am skeptical is for a Three Disc set to include 4 versions plus extras, seems a bit much.
Actually I think you could easily fit 4 versions on 3 DVD's.
The only real diffrence between the theatrical and director versions is the voiceover, one additional scene, and one removed scene. That should be a piece of cake to seamless branch. As for the workprint I think you could probably simply branch the extra footage on to the theatrical/director's cut you already have. That's one disc.
Then present the "final director's vision" cut on the other disc with whatever commentary and audio tracks you want. Two discs.
Then put all the extras on a seperate disc. Three discs.
Here's hoping WB will to the right thing.
