Blade Runner DVD - which version to buy?
Discussion in 'Archived Threads 2001-2004' started by John Morris, Aug 21, 2001.
  1. John Morris
    John Morris Guest
    NOTE: Sorry for posting something this simplistic, but the HTF Search function is down...
    I just went online to finally buy Blade Runner DVD and found 2 different packages, one $20 and another $58. But, Both seemed to NOT use the Harrison Ford voiceover and both used the unhappy ending.
    Is there a package which includes both the theatrical and the directors versions? If not, is the $58 DVD (image and sound, not extras)twice as good as the $20 DVD?
    Thanks for your help!
    Take Care,
    merc
    DFAST, 5C, DVI, HDCP, SafeAudio, Macrovision and Lewinski!!!
    [Edited last by John Morris on August 21, 2001 at 05:37 PM]
  2. Andrea W
    Andrea W Supporting Actor
    Mar 19, 2001
    777
    Andrea Whitlock
    A special edition is in the works. I would wait for that.
    http://darius.mobius-soft.com/~andrea/ht/
    [Edited last by Andrea W on August 21, 2001 at 05:43 PM]
  3. Michael Reuben
    Michael Reuben Director
    Feb 12, 1998
    21,763
    3
    5,110
    Michael Reuben
    There's only one DVD version of Blade Runner. The more expensive item is a deluxe package that contains the same disc and various non-disc extras (I forget exactly what). Only the so-called director's cut (minus the voiceover and the tacked-on happy ending) has been released on DVD.
    Strong rumors of a new special edition have been floating around for well over a year, but there's no firm date and no definite information on what version(s) of the film will be included.
    M.
    [Edited last by Michael Reuben on August 21, 2001 at 05:55 PM]
  4. John Morris
    John Morris Guest
    Andrea and Michael: thanks for the info. I think I'm gonna hold off getting this one. Maybe it's time for some family Goonies! [​IMG]
    Take Care,
    merc
  5. Michael Reuben
    Feb 12, 1998
    21,763
    3
    5,110
    Michael Reuben
    One other thought: Blade Runner was in the very first wave of Warner DVD releases back in spring 1997. I'll bet you could find a cheap used copy without too much effort, if you want something to tide you over.
    M.
  6. Andrea W
    Mar 19, 2001
    777
    Andrea Whitlock
    You might want to read this thread for a little info on the special edition:
    http://www.hometheaterforum.com/uub/Forum15/HTML/028636.html
  7. Michael Reuben
    Feb 12, 1998
    21,763
    3
    5,110
    Michael Reuben
    I can save you some time, John. Here's Charlie's one-line summary (posted just over 3 weeks ago):
  8. Edwin-S
    Edwin-S Lead Actor
    Aug 20, 2000
    7,362
    1,032
    9,110
    A little off topic but I thought I would ask anyway. On the opening sequence during the city flyover, on my TV I noticed a horiz. banding that sort of undulated across the screen. I was wondering if anyone else has noticed this effect and whether it is caused by early compression routines. The player I was using was a Toshiba SD3109. I found it distracting, to say the least.
  9. AdrianJ
    AdrianJ Supporting Actor
    Apr 1, 2001
    532
    If you are a Blade Runner fan, just pick on the disc by itself. It could be years before we actually see the special edition.
    [​IMG]
    Adrian Jones
  10. Michael Reuben
    Feb 12, 1998
    21,763
    3
    5,110
    Michael Reuben
  11. Andrea W
    Mar 19, 2001
    777
    Andrea Whitlock
  12. Frank L
    Frank L Stunt Coordinator
    Jul 23, 2001
    139
    I'd venture to say that if you're a fan of the movie, then I suggest you pick up the current version.
    I think the upcoming SE will probably be a different (new) cut of the movie, so if you want to have this, so-called, director's cut in order to have both version, then it's worth picking it up.
    F
    [​IMG]
