Blackout cloth question (1 Viewer)
BrianKR
Project the image on the cloth or rubber side?
Does it make much of a difference either way?
Eric Samonte
Usually, image is projected on the rubbery side...the grey side. Although u can always check it out urself which looks better for u. Remember the dictum, " Regardless of what others say, if it works for u, to hell with them! "
BrianKR
Thx for the input!
The screen is built and my new toy just arrived via Fed Ex!!!!!
Now all I have to do is hang it, wire it and FIRE IT UP! :D :D :D :D :D
Brad E
I use the cloth side because the rubber side had some imperfections. Looks great although I never did compare the two.
What side did you go with?
BrianKR
I went with the rubber side.
It's only a temporary screen. Within the next fews weeks I am going to order one once I make up my mind which direction to go in. My wife says this one is good enough. She can't see how the picture will improve with a different screen.
Maybe after I calibrate the projector I will agree with her ;)
absplumbing
