Black Box on Toshiba 27A41C
Discussion in 'Archived Threads 2001-2004' started by Andrew S, Mar 29, 2002.
  1. Andrew S
    Andrew S Stunt Coordinator
    Sep 30, 2001
    214
    Recently I've been noticing a small black bar at the bottom of the screen on our tv, Toshiba 27A41C. My sister has noticed it more than I, and says that it appears every once in a while, and on some channels more than others.
    Does anyone have any similar experience with this tv? I know I see it mentioned a lot as a good bang for you buck TV, so are there any other members with the same problem?
    Andrew
  2. Bill Slack
    Bill Slack Supporting Actor
    Mar 16, 1999
    837
    Check your closed caption settings in the TV menu (set it to off)
