dusty
- Jul 11, 2001
I am having some confusion with the settings of my audio sources. I have two DVD players, both connected digitally. In the setup of the players, there is option for Dolby Digital to be PCM or Bitstream. When I set it to Bitsream and play a DD source, the red Dolby Digital light appears on my receiver (Onkyo TX-SR501). However the bass response is very weak, if anything. When I put the player in PCM mode, I get a much higher bass response. I'm not sure if there is a problem with my receiver, or if this is expected behavior.
Another note, I couldnt get ANY bass output when using the Avia calibration disc and Bitstream mode on my DVD player. I changed it to PCM and the room was rattling.
Dusty
Dusty
