Bitmaps? Why?
Discussion in 'Computers' started by John Watson, Aug 10, 2003.
  1. John Watson
    John Watson Screenwriter
    Jul 14, 2002
    1,937
    Bitmaps. What gives? I was just visiting a site where I used to find nice Sarah Michelle Gellar wallpaper type images, and find they are all Bitmaps now, instead of jpegs.
    They can be downloaded just as easily, but bitmaps tend to be much bigger files, and only display in Paint on my Windows 98 operating system. Is there a way to convert them to jpgs?
    Is the site concerned trying to discourage downloading?
    Seems bizarre considering it's a fan site.
  2. Joel Mack
    Joel Mack Cinematographer
    Jun 29, 1999
    2,317
    Maybe your temporary files directory is full? Does this happen with every image file you try to right-click and save?
    If so, go to Tools, Internet Options, and Delete Files.
  3. Rob Gillespie
    Rob Gillespie Producer
    Aug 17, 1998
    3,632
    5
  4. NickSo
    NickSo Producer
    Jul 2, 2000
    4,260
    Nick So
    Yeah, i;ve had that happen to me before too, where when you save the images they;re only available as BMP or GIF... I think you gotta empty your internet cache or something... I forgot what I did, but its working again...
    That really pissed me off though when it was happening
  5. Christ Reynolds
    Christ Reynolds Producer
    May 6, 2002
    3,597
    CJ
    here is the solution, i hated this more than anything, very frustrating. anyway, this should work.
    CJ
  6. Demetri K
    Demetri K Stunt Coordinator
    Dec 29, 2001
    133
    The reason why they do that is jpeg tends to make images look muddy sometimes. Perhaps the person running the site was concerned with quality.
  7. MarkHastings
    MarkHastings Executive Producer
    Jan 27, 2003
    12,013
  8. Wayne Bundrick
    Wayne Bundrick Cinematographer
    May 17, 1999
    2,358
    They should use PNG, it is compressed but it's lossless so it's more like ZIP than JPEG.
  9. Max Leung
    Max Leung Producer
    Sep 6, 2000
    4,611
    They are probably jpegs...as Nick and Christ point out, it is likely a problem with the browser converting all images to .bmp or .gif without the user's knowledge, and nothing to do with the website.
  10. Kyle McKnight
    Kyle McKnight Cinematographer
    Mar 8, 2001
    2,504
    For any graphic viewing purposes, I reccomend
    Irfanview
    A great, very small program.
  11. Christ Reynolds
    May 6, 2002
    3,597
    CJ
  12. Mark Dubbelboer
    Mark Dubbelboer Screenwriter
    Oct 6, 1999
    1,008
    i second the irfanview recommendation
  13. John Watson
    Jul 14, 2002
    1,937
    Thanks for all the responses, everyone. I clear my TIF cache regularly, so that's not the problem.
    I think I followed Rob's suggestion, and I then get a jpg version of the bitmap file, but it's just as large in kb's as the one in Bitmap format, and doesn't open anyway.
    I tried the technique in Christs' link, and have one unknown file in the Objets.
    Anyway, the problem only occurs on very few sites, the vast majority show as jpgs, so it probably is something associated with the one site, and if bitmaps take a lot more expensive bandwidth, its puzzling.
    Some sites disable image downloading, so perhaps using bitmaps is another way to accomplish that.
    Anyway, thanks for all the info/tips. [​IMG]
  14. MarkHastings
    Jan 27, 2003
    12,013
    I just quickly re-read the thread and I don't think anyone has mentioned the browser issue. I use Netcape and Explorer because I find that a lot of the scripting that they use in Explorer, to discourage image downloading (especially the not being able to right click), isn't a problem in Netscape.
    If I am to download any image, I use Netscape. I too ran into situations where I would try to save a JPG to my computer and Explorer would only save it as a bitmap. In fact, it wouldn't even hold onto the name, it would save it as "untitled.bmp".
  15. Kimmo Jaskari
    Kimmo Jaskari Screenwriter
    Feb 27, 2000
    1,528
    BMP files are what Windows uses "natively" for desktop backgrounds. Back in the Win 95 days, before they started integrating IE, you could use nothing but BMP.
    BMP's are the best choice if you want pixel-perfect desktop background images at full color. GIF can't do full color, and JPG is lossy.
    PNG is, of course, even better but I doubt if you can take a PNG and use that directly as a desktop background.
    Granted, with software like ACDSee you can have it convert automatically to a desktop background; they way that is done is that it automatically resizes and saves the image - as a BMP file.
  16. Joel Mack
    Jun 29, 1999
    2,317
  17. Wayne Bundrick
    May 17, 1999
    2,358
