Birch Hardwood from Home Depot
Discussion in 'Home Theater Projects' started by Rick Westfall, Jan 3, 2004.
  1. Rick Westfall
    Rick Westfall Stunt Coordinator
    Dec 8, 1998
    220
    Anyone use this material for building their sub enclosure? I priced both the MDF and this birch (48" x 96" sheet). MDF is about $18 and the birch is about $30. Looks like I can just stain the birch after some sanding. The MDF I would have to veneer or something to get a good stain on it. Seems like the birch would require less work. Any thoughts on why I would want to go with MDF over the birch?
    Rick
  2. Mitch_J
    Mitch_J Stunt Coordinator
    Oct 16, 2003
    129
    I read somewhere that real wood has weaknesses and cracks in it that may show up later on down the road where as MDF and better yet HDF is uniformly solid now and in the future.
    I believe that is why Edge Audio Now Aperion Audio switched from real wood to HDF.
    (Shrug) hope it helps
  3. Baldemar Garcia
    Baldemar Garcia Stunt Coordinator
    Feb 4, 1999
    141
    I'm pretty sure he meant to say Birch plywood. In that case, I would not recommend HD's for sub enclosures. IME, it is low quality in terms of voids within the plys. And you'll notice only one side is 'cabinet quality' (and barely that). So you'll have to plan your construction one extra step (no big deal really). But I'd stick with the uniformally dense MDF.
  4. Rick Westfall
    Dec 8, 1998
    220
    Baldemar...thanks for the clarification. I did mean to say Birch plywood. I guess that changes things [​IMG]
  5. TimForman
    TimForman Supporting Actor
    Dec 4, 2002
    847
    I would agree. After using both materials I would recommend MDF for sub enclosures. You could use a veneer over the MDF when finished. At this point I'm favoring a quality plywood for mains, etc., with either hardwood corners or veneer banding tape to hide the edges.
  6. Wayne Ernst
    Wayne Ernst Cinematographer
    Feb 24, 2002
    2,588
    Tim, Is there any reason why you wouldn't just miter the corners and avoid the additional veneer banding? You could also use internal braces to hold the mitered corners together.
  7. Hank Frankenberg
    Hank Frankenberg Cinematographer
    Oct 13, 1998
    2,573
    Actually, for a subwoofer enclosure, good plywood would be okay, because the density of MDF doesn't help at subwoof frequencies, as I recall - only to bass/mid-bass frequencies.
    Someone please correct me if I'm off base.
  8. TimForman
    Dec 4, 2002
    847
    You wrong Hank? Nawwwww.....
    I built a sub with plywood and MDF bracing. It came out great. I'm just thinking if cheap and simple works then why not? I guess if you want the wood grain look and don't want to mess with veneer then plywood is the best option.
  9. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
    I bought some "Baltic Birch" ply at Home Despot in 2x4 sheets. Great stuff, no voids I could notice at all. My preferred material for sub boxes. Not cheap, though.
  10. Allen Ross
    Allen Ross Supporting Actor
    Sep 30, 2002
    819
    I would recommend a lock Miter joint then it is mega strong, and gives you a prefect 90 degree corner.
    [​IMG]
    thats true 13 ply BB with a lock miter joint.
  11. Jack Gilvey
    Mar 13, 1999
    4,948
    Rad joint, dude! I guess you need a router table for that? I've wanted to try that one if just for ease-of-alignment purposes. Fwiw, that's just what the cross-section of my HD ply looks like.
  12. Allen Ross
    Sep 30, 2002
    819
    yeah i dropped some serious cash on my router table and it does lock miters wonderfully.
  13. Bob Kavanaugh
    Bob Kavanaugh Second Unit
    Jan 17, 2003
    282
    Allen, is there a reason you went across the grain on that joint? Your veneer got a little torn up there. Going with the grain would make a perfectly smooth cut. Nice Plywood by the way, I wish I had access to high quality wood down here. [​IMG]
