BIOS won't recognize new drive (1 Viewer)
Bill_Mis
I have a Dell 4700 that had a dual drive with dvd-rom on top and a cd-rw drive below it. Yesterday I swapped out the cd-rw drive for a Pioneer dvd-rw model 110. My problem is that BIOS does not see it and I get stopped at start-up by BIOS. If I F1 and continue its fine and windows definitely recognizes and identifies the drive. I updated the BIOS to the most current as well as flashed the new Pioneer drive with no luck. Any ideas why the BIOS don't see the new drive?
Bill_Mis
Dell use the Cable Select setting for both drives so I stayed consistant with that.
Bill_Mis
I did set the jumper seting on the Pioneer to cable select. It shipped with the jumper on master but I switched it to cable select because the Samsung cd-rw I replaced had it in that position and from what I understand Dell configures their drives in this manner. Since windows recognizes the Pioneer no problem and BIOS does not I am suspecting something besides the jumpers is the problem. If the jumpers were incorrectly set would Windows recognize it and allow it to function properly playing cd's and dvd's?
Patrick Sun
Have you emailed Dell's tech support about this issue?
Another thing you can try is to jumper the slave drive as a slave, and the master drive as a master, and see if that help in getting the BIOS to see it and pass through it.
Deecee
