John Wilson
- Jul 6, 1999
This is a follow-on to my other thread here where I had some questions about using DI 2002's Drive Copy utility. Well, I went ahead and copied my 20GB C: partition to a 40GB hard drive. The copy went okay but I didn't tell DI to hide either the source or destination drives after the copy. After the copy, it rebooted but gave me 3 sets of Windows XP Pro OS to boot from. I tried the 1st one and it booted just fine. It sees the 20GB "copy" on the second HDD and it is active. I had hoped that the copy would have been expanded to use the whole 40GB but it still has ~18GB of unallocated space.
Here is the real issue. I powered down and disconnected the IDE and power cables of the second (primary slave) HDD and powered on. Again, I get a choice of 3 sets of Windows XP Pro. I tried each one and only the 1st one works so the other 2 must be on the disconnected HDD. I want to go back to just the original drive but I don't want to have to wait while the boot up sits and waits for me to pick an OS. :frowning:
Did something get changed in the Bios? Can I fix it? Its an Award BIOS on an EPOX MB with a P3-800 and 768MB of SDRAM MMY.
I thinks I'm going to have another look at Norton's GHOST.:b :b
Thanks for your help.
EDIT: Is it possible that since I didn't choose the "hide" option for either the source or destination drives during the copy that 2 additional Master Boot Records (MBR) were added to my original drive? I've tried a system restore to a point prior to installing Drive Image but it did not get rid of the OS choices menu. Can I edit the MBR? How about if I try to do an OS repair using the XP CD? I'd like to avoid reformatting but at this point I'm willing to try anything! Dumb me!:b
