Binding Posts? Banana Plugs?
Discussion in 'Archived Threads 2001-2004' started by Steve_W, Dec 1, 2001.
  1. Steve_W
    Steve_W Agent
    Nov 13, 2001
    37
    I am setting up my Def Tech BP2006TL Mains and need advice on how to connect them to my Onkyo 898.
    I have 12 guage wire to connect them. The speaker terminals are binding posts.
    What do I need to connect them? What about banana plugs?
    Complete newbie so thanks for the help.....
  2. Steve_W
    Steve_W Agent
    Nov 13, 2001
    37
    bump
  3. Jo_M
    Jo_M Stunt Coordinator
    Dec 12, 2000
    168
    If I'm not mistaken you have 5way posts on the deftech's. You can get some gold banana plugs (I use the screw type) and hook them up that way. If the Onkyo has the same type of posts, get banana plugs for those as well. Make sure the posts are screwed down all the way before you plug in the bananas.
  4. Steve_W
    Steve_W Agent
    Nov 13, 2001
    37
    Thanks Jo
    I'm not sure what a 5way binding post looks like, and I cant find it on the Def Tech website, so I'll take your word they are 5 Way binding posts.
    Now another question...where should I get the banana plugs? Any specific type??
    Steve
  5. Matthew Anderson
    Matthew Anderson Second Unit
    Sep 24, 2000
    281
    Garland,Tx.
    Matthew Anderson
    Radio Shack and Parts Express have a good selection of banana plugs. I like spades for my speakers but that is just my preference.
  6. Chris PC
    Chris PC Producer
    May 12, 2001
    3,975
    Those 5-way binding posts are on my PSB speakers and I believe they are also on my Marantz receiver. Why are they called "5-way" binding posts? You can crimp wire or a spade plug I think, and also use a banana plug. Why are they called "5-way" binding posts? What are the 5 ways of using them?
  7. StephenL
    StephenL Second Unit
    Nov 21, 2000
    341
    I'm using Radio Shack 274-717 dual inline banana plugs with my Onkyo 898. They provide a convenient, tight connection. There's no benefit in spending more money on gold plugs since the 898 doesn't have gold jacks.
  8. Brett DiMichele
    Brett DiMichele Producer
    Sep 30, 2001
    3,181
    Chris,
    They are refered to as 5 Way Binding Posts because you can
    Bind a wire to them in 5 diffrent ways.
    #1: Banana Plugs
    #2: Spade Lugs
    #3: Bare Wire Inserted Through The Hole
    #4: Pins
    #5: Bare Wire Wrapped Around The Post
    There ya go [​IMG]
  9. Allan Jayne
    Allan Jayne Cinematographer
    Nov 1, 1998
    2,404
    If you can get the bared ends of the wires securely fastened directly to the binding posts ...
    AND ...
    If you don't expect to keep taking the connection apart and re-doing it several times a year as in moving the equipment for cleaning or relocation ...
    THEN ...
    Don't bother with banana plugs or spade lugs.
    Other video hints:
  10. Brett DiMichele
    Sep 30, 2001
    3,181
    Allan,
    Sorry but IMHO bare wire termination is the most chinsey
    way to connect a speaker. Not only does wire oxidize and
    must be disconnected every year or so to strip the wire
    back anyway but you also run the risk of having a stray
    wire cause a short.. No way would I use bare wire to
    connect my system. If your worried about regular Banana's
    not being good enough then look at WBT Locking Split Pin
    Banana's they cost $80.00 per 4 and are undoubtedly the best
    that money can buy.
