Binding post
Discussion in 'Archived Threads 2001-2004' started by Rick Thomas, Apr 3, 2002.
  1. Rick Thomas
    Rick Thomas Agent
    Feb 27, 2002
    36
    Can someone recommend some good binding post for my sono sub
    and where to get them thanks.
  2. jeff lam
    jeff lam Screenwriter
    Jun 4, 2001
    1,798
    San Jose, CA
    Jeff Lam
    I chose these from Partsexpress:
    http://www.partsexpress.com/pe/showd...14966&CATID=39
    They are a little pricey but the quality is superior to just about anything else you'll find. The dual terminal one is also popular but I only had 1.5" to work with on my endcap and the dual terminal one wouldn't fit.
  3. Mike Strassburg
    Mike Strassburg Second Unit
    Nov 4, 2001
    421
    Also check out Madisound as I got something VERY similar for $3.20 shipped....
  4. PeterV
    PeterV Agent
    Dec 17, 2001
    32
    Also used the Yung(Y6-PostB) binding posts from Madisound. They have a 45mm long shaft and worked good for my sonosub application.
  5. Greg_R
    Greg_R Screenwriter
    Apr 9, 2000
    1,996
    Portland, OR
    Greg
    I got the Dayton's and they work well. Since my enclosure was 3" thick I had to sink a hole from the inside (posts weren't long enough). I filled these holes with sealant after fastening the connectors (figured it would keep the wire from seperating from the post connector).
