Big problem with harmankardon receiver, please, please help me!!!
Discussion in 'Archived Threads 2001-2004' started by Albert Hernan, Feb 16, 2003.
  1. Albert Hernan
    Aug 4, 2002
    17
    Hi, my system is the HK AVR225 and 5 JBL speakers
    The problem is the following:
    Almost always, after some minutes of beginning a movie the front left an rigth speaker make a sound like: PUFF! and they stop the sound, and they work the next day again (aprox. after 10 hours).
    But, the problem is not the speakers, it is the reciever because I change the rigth or left speaker to the central position and they work perfectly, and I change the central speaker to the position rigth or left channel and it doesn't sound.
    Which will the problem be? please help me!!!
    Sorry for my bad English.
    Thanks!
  2. John S Choi
    John S Choi Agent
    Jan 25, 2003
    29
    TRY RESETING the whole system.
    Run only main speakers for while in stereo mode only.
    It seem like is from either front amp or microprocessor.
  3. Albert Hernan
    Aug 4, 2002
    17
    Yes, I'm just reset rigth after post this thread but it doesn't solve the problem..... : ( thanks John.
  4. Albert Hernan
    Aug 4, 2002
    17
    Help! [​IMG]
  5. Brian_Tho
    Brian_Tho Stunt Coordinator
    Jan 8, 2003
    175
    Get a different receiver!
  6. CurtisC
    CurtisC Second Unit
    Jan 7, 2003
    369
    I second the different avr,I have heard this before.good luck.
  7. Doug Brewster
    Doug Brewster Second Unit
    Jul 22, 2002
    325
    If all the speakers are the same, it's definately a problem within the receiver... Or(the only other slight possibility)the speaker cable... Doubt that's it...
    Doug
  8. Jose G
    Jose G Supporting Actor
    Aug 18, 2002
    568
    I own an HK 225 and what you are describing shouldn't be- return it and get a new one ASAP!
