CRyan
- Feb 9, 1999
Well, have no idea what has happened. When I go to a particular page that normally has a Passport pop-up sign-in window, I do not get the pop-up - just a blank white browser page.
I have tried putting all my security options to low to no avail. I have turned off my Norton Antivirus 2002 and unistalled zonealarm to be sure that was not the problem. I have tried both my cable modem and dial-up to make sure it was not an ISP issue. I know that it is not a web site issue as a friend was able to get it up using IE on another computer.
I have tried to use Netscape 6.2 and I can get in with that. HOWEVER, it does not recognize the VBScript on the page I am trying to open and gives me a Microsoft VBScript runtime error '800a0005' Invalid procedure call or argument: 'InStr
I tried Opera but it does not understand the JAVA date input so it makes the page useless as it does not recognize the correct date input (mm-dd-yyyy).
PLEASE HELP.
I have Windows XP PRO and there is no listing for IE under Add-Remove Programs, so I don't even know how to unistall-reinstall or repair.
Thanks for any help. This is really important to me.
C. Ryan
PLEASE HELP.
C. Ryan
