Big difference between Axiom M80 vs. M60? (1 Viewer)
Bryan_Tams
Not sure that I need the M80's as I am filling a 18x16 cathedral room but if there is a significant difference in sound from the M60's for a couple hundred dollars I would consider it. Thanks.
JimC_A
Go to the Axiom website. There is a good thread on a comparison of the towers. That would be a good place to start. I have the 60's and I'm completely satisfied.
Ben_Page
Same here my M60s are great. Check the web-site one big item I noticed was the difference in impedance (8 versus 4) between the M60s and M80s respectively.
