Big black U in middle of screen (1 Viewer)
chiaThomas
I have a D56W20 RCA tv that has a big black U shape in middle of screen,about 8in from each side. The U goes from bottom to top of screen, this stays on the screen even when turned off. I have had this tv for 3yrs, been nothing but trouble with this screen...it developed green streaks less than 5 months after I bought it, had the screen cleaned made the streaks a lot worse.. The shop said screen was defected but RCA said it was not so no replacement. Anyone know what this could be? It is getting worse each day.
Will_B
Do you have unsheilded stereo speakers sitting next to each side of the set?
Can you post some pics of it?
David Norman
Has it been cleaned inside recently? I wonder if something has fallen into the projection lens and you're seeing the shadow of maybe a dustball though I'm not sure if would be seen with the set turned off. Maybe a problem with the renticular screen -- warped or dirty?
JoeyT66
