bic america subwoofers?
Discussion in 'Speakers' started by BruceTM, Feb 26, 2003.
  1. BruceTM
    BruceTM Agent
    Feb 7, 2003
    49
    I have been reading the specs on the bic v1015 and v1215 subwoofers. Does anyone know anything about these? The prices are certainly right. Should I order one of these?
  2. Dale B
    Dale B Stunt Coordinator
    Oct 5, 1999
    55
    Don't know about the sub, but am using the small bookshelf speakers for my mains and think they are quite good for the price. I am very happy with them. I know this don't answer your question about the sub, but I think Bic speakers are very good for a not very well known or talked about speaker.
  3. Ken Custodio
    Ken Custodio Second Unit
    Dec 5, 2001
    316
    I had the 1215 that I bought from Ubid, it was an ok entry level sub. It is better than nothing, but it made a loud pop when ever it auto powered down. I replaced it with a JBL sub, and it sounded much better, then I bought a SVS which sounds A LOT better [​IMG]
    I thought the bass in the Bic sub didn't have a deep bass sound, it sounded there wasn't enough insulation in the box or the box wasnt very sturdy. But for the price it wasn't bad, I think I got it for $70 off of Ubid.
  4. BrianHo
    BrianHo Agent
    Apr 12, 2003
    41
    Anybody else have one?
  5. MarkO
    MarkO Second Unit
    Feb 19, 1999
    309
    I had a small 8 inch ported sub from BIC years ago. It acually put out clean unboomy bass for such an inexpensive sub.
  6. felix_suwarno
    felix_suwarno Screenwriter
    Dec 2, 2001
    1,523
    bic??? i thought they were ballpoint manufacturer!
  7. ErichH
    ErichH Screenwriter
    Mar 1, 2001
    1,163
    Had a 1212 for a few months. For the money, it was very good. The twin Venturi ports are a good design.
    As with any inexpensive sub, we did the liner/bracing/stuffing mod and the results were excellent.
    If I only had 200 to spend on a 12, it would be one of my first choices.
    Once you go past the 300-350 mark, it's hard not to think about an entry SVS.
    Eric
