shoe88
- Dec 24, 2011
- Sidran Shu
Looking to purchase a pair of either to replace my floorstandings which have blown tweeters, these are quite old so thought I may just replace them instead of repair. I purchased a FH6 already to replace a center from a Klipsch Quintet (whole set has been moved to a different room) and I was blown away at what I was missing from my center channel. Albeit the Quintet was a midget compared to the FH6 but never-less I want a whole set of this series. The FH6 and FH65B to me share similar specs, but it's safe to assume you fellows here know a lot more about these numbers than I do. From the BIC website: FH6-LCR: 175-watt two-way 3 driver, all channel speaker 95dB sensitivity 1 watt/m Dual 6 1/2" Woofers + Horn Tweeter FH65B: 375-watt 2-way horn bookshelf 96dB sensitivity 1 watt/m 6 1/2" Woofer + Horn Tweeter Both recommend up to 175W RMS per channel and as far as I can tell the only difference between the 2 is that the FH65B has a rear port while the FH6 is sealed. Plus the obvious second speaker. I am using a Onkyo HT-RC360 Receiver and this is a 5.1 setup w/ a BIC V1220 subwoofer. Long term plan is to buy a pair of either of these now to replace the fronts, then later on purchase the floorstanding version of these speakers (FT-6T) and move these to be the rears. Suggestions?
