amatala
- Mar 19, 2004
Hello,
I am currently considering bi-amping my fronts but I am not sure if two medium-powered amps in a biamp setup would give better results than a single higher-powered amp.
To be very specific, when using amps of the same brand and same construction, would it be better to use two amps of 2x45W to power the fronts in a biamp config or it is better to stick with only one amp of 2x100W in a 'normal' single amp config?
I currently own 2 H/K PA2000 power amps which can work as 2x100W in bridged mode or 4x45W in non-bridged mode (which would allow me to do biamping). So ... which way, which way?
Any comments are welcome!
Thanks!
Thanks!
