Bi-Wiring
Discussion in 'Archived Threads 2001-2004' started by Theron Renfro, Feb 9, 2002.
  1. Theron Renfro
    Feb 3, 2002
    15
    Does it make a difference? The speakers are Infinity Interlude IL30's. They will be used as front l/r.
    Thanks in Advance
  2. JohnMW
    JohnMW Second Unit
    Dec 1, 2000
    280
    It's a subjective answer, but I biwire my fronts. Try searching for biwire and read thru the old threads.
  3. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    there are some relatively simple experiments you can perform that'll answer that question to your satisfaction. it'll require the assistance of two other people. let me know if you're interested.
  4. MichaelGomez
    MichaelGomez Stunt Coordinator
    Oct 4, 2001
    134
    I bi-wire mine but there are plenty for and plenty against.
    Then there is the cheap method.
    A lot of people think that the real improvement is from replacing the buss bar. This is an easy experiment. Just replace the buss bar with a small run of your speaker wire.
