BrettisMckinney
- Aug 25, 2002
Hey guys, i'm using Paradigm Monitor 7's through my yammy rxv496 and when i purchased them the guys there made me up a bi-wired cable. They said it would be better and told me how to connect it. Anyway, lots of time has gone past and I thought that maybe since I dont know anything about bi-wiring, I should ask this question...
On the connections to the speaker, they told me to put the thicker/fatter wire to the top(high frequency) and the thinner/lighter cable to the bottom(low fequency). Does that sound right to you? I would have thought for better bass response a thicker cable would be required. Or would it be a special type of thin wire designed for bass?
I'd hate to have been using it the wrong way around! Any suggestions would be awesome.
