Kevin Flanagan
Grip
- Jul 18, 2000
I just upgraded my receiver from a Denon 3200 to a 2802. From the model numbers, it doesn't look like an upgrade, but that's a whole different discussion.
On the 3200 there are 4 binding posts for each front speaker, specifically to make biwiring easy. The 2802 also has 4 binding posts, but the speakers are split into 2 separate systems, A and B, and each is switchable from the front panel and remote. In the Denon manual it states:
Be careful when using two pairs of front speakers (A + B) at the same time, since use of speakers with an impedance of less than 8 §Ù/ohms will lead to damage.
My speakers are Energy Veritas 2.2s, with 8 ohm nominal, and 4 ohm minimal impedance.
My question is this:
Can I safely bi-wire the speakers using both the A and B posts, and running power to both systems, or should I only connect to one set of posts?
-K
Link Removed
-K
Link Removed
