Bi wire VS. regular speaker wiring (1 Viewer)
MarkLaf
My center channel has 4 binding posts so I bought some better cables bi wire and I was amazed at hpw much cleaner everything sounded. Now my tower speakers only have the normal 2 binding posts would I notice a difference if I were to bi wire those as well?
Thanks, MArk
Chu Gai
A very controversial subject! Consider the following thread which dealt with biwiring Paradigms. At the very end of the thread, a method is presented whereby you can determine for yourself whether biwiring makes a difference.
Mark Rich
I tried Bi-wiring my Paradigm Ref speakers using Canare 4S11 wire. Could not tell the difference.
I also tried Bi-amping these same speakers and there was a very noticeable improvement. If you have a spare amp its worth trying.
Philip Hamm
Wow if everything sounded amazingly clearer after snake-oiling biwiring your original speaker cables must have been dreadful!
MarkLaf
Not really I had monster cable original before and bought some better cable bi wire!
babarrun
