John Royster
- Oct 14, 2001
I wanted to try out bi-wiring my speakers and overall to try out some different speaker cable. The results that follow are VERY surprising and really did shock me in the differences I and my wife heard. Mind you in these test I didn't tell my wife what or if I had done anything but simply asked "describe what you hear."
gear - adcom gcd700 cd player, HK 8800 integrated amp (100x2), Martin Logan reQuest speakers.
Cables - 2 pairs of home depot 12 gauge speaker wire, monster cable (something like 200 bucks way back), audioquest cobalt I believe speaker wire. Keep in mind the speakers are firmly anchored with spikes and 50 lbs of weight on each speaker, they ain't movin'.
We've been accustomed to the audioquest for speaker cable in regular fashion, single pair per speaker and were pretty familiar with the sound. There are some favorite test tracks from Peter Gabriel, Santana and Janet Jackson because the recordings are great and the range of each can really shine depending on the speakers in question.
Audioquest (single pair attached to the high inputs on speakers with jumper in place) - good, smooth bass, clean highs, detailed but somewhat thin sounding, collapsed soundstage, good imaging but confused sometimes.
Monster Cable (single pair attached to the high inputs on speakers with jumper in place) - decent, distorted vocals, didn't have the crispness I'm used to, bass is a tad muddy, soundstage is collapsed between speakers, imaging is poor.
HD cable (dual pairs to each speaker, bi-wired with jumpers removed) - Deep, lots of bass. Bass is tighter and more pronounced. lower midrange and vocals tend to bloom and overpower the highs. Loss of upper highs so much so that we both questioned what happened to some instruments. Lost that "air" of the soundstage. Again, lots of bass, vocals are smoother but at what cost?
HD cable (single pair attached to the high inputs on speakers with jumper in place) - Nice, bass is tight. Great soundstage extending beyond speakers with good depth. vocals are spot on but "maybe" a slight harsh, highs have a good air. imaging very good.
I post this only because I am truly amazed at the difference between the cables/methods. Yes I'll state here that it was quite profound. For now I'm sticking with the home depot single pair.
BUT!!!! Picking a better or worse was somewhat difficult and required switching back and forth and calling the other into the room. We both could accurately (blind I might add) tell what was happening with our favorite tracks. The bi-wire seemed to drown out the highs with midrange and bass so that one was out. We prefered the soundstage and richness of the HD single pair.
Go figure. I'm a bit surprised myself. Now I'm not going to try and explain it, but that's what we heard both being amateur musicians. Heck, it was worth me spending 15 bucks on cable just to try. We are convinced beyond any shadow of a doubt that speaker cables do indeed sound differnt, VERY different. Does an expensive cable sound "better" than a less costly one? Don't know - listen and decide for yourself.
FWIW,
FWIW,
