Bi-amping with an A-B Receiver
Discussion in 'AV Receivers' started by Jack*Mains, Dec 1, 2003.
  1. Jack*Mains
    Jack*Mains Stunt Coordinator
    Sep 25, 2002
    156
    Hey everyone, I was just wondering if it would be beneficial in any way to use the A-B outputs on a receiver to bi-amp a pair of speakers.
    I have a Yamaha RXV730 which can go down to 8 Ohms into both channels, or 4Ohms when either of the channels is used.
    Since under normal conditions, there is a bridge across both sets of terminals on the speakers, and the combined load is about 8Ohms, I am assuming that the load becomes 16Ohms on each terminal when bi-amping them.
    But the real question is: is it really worth it using both of the A-B channel to bi-amp, or does it simply split up the signal from the same amp?
  2. BrianWoerndle
    BrianWoerndle Supporting Actor
    Feb 19, 2002
    794
  3. Jack*Mains
    Sep 25, 2002
    156
    In that case I guess I can use the extra set of binding posts without having to cram 2 12g wires into one.
  4. Mike Veroukis
    Mike Veroukis Second Unit
    May 8, 2001
    455
    Canada
    Michael
    Both the A and the B terminals are connected to the same amp, so you're not really bi-amping but bi-wiring. It doesn't matter if you hook up two pairs of wires to the same terminal or use one terminal per wire, it's the exact same result - the split just happens at different places.
    - Mike
  5. John S
    John S Producer
    Nov 4, 2003
    5,460
    Bi-wire'n can have some benefits though. I don't do it, but I know people that do.
