Bi-Amping Question
Discussion in 'Home Theater Projects' started by Tom McDonald, Feb 17, 2004.
  1. Tom McDonald
    Tom McDonald Stunt Coordinator
    Feb 24, 2002
    90
    Thought I posted this before but can't find it so I will try again. If you have a 7.1 amp but are only running a 5.1 set up can you use the 2 extra channel to bi-amp your front 2 speakers? Just wondering, this is a great site for quality info and I really enjoy everyones input, thanks.
  2. Wayne A. Pflughaupt
    Aug 5, 1999
    6,123
    40
    6,610
    Katy, TX
    Wayne
    If by “amp you actually mean “amp” and not “receiver,” then yes you could use extra channels to bi-amp. It could be done on a receiver, but only of the extra channels have separate input jacks. Some receivers have them on some channels; few have them on all channels, and usually it is the secondary channels that don’t have them.
    Wayne A. Pflughaupt
  3. Tom McDonald
    Feb 24, 2002
    90
    Thanks Wayne, and yes I do me a Amp, I was thinking of upgrading with the Outlaw 770 and wanted to make sure that this was possible. Thanks again
