Ken Custodio
- Dec 5, 2001
If you bi-amp a set of front speakers, are you essentially doubling the watts to your speakers or is it the same watts, since one channel goes to the tweeter and one goes to the woofer?
Now what happens to the impedance of the speaker? i.e., if I have an 8 ohm speaker, and I remove the bridge from the terminals, do I have two 8 ohm loads? Or two 4s? Or two 16's?The speaker’s nominal impedance, as measured at the speaker terminals, is determined as much by resistor networks used in the passive crossover as the impedance of the drivers. In all likelyhood you will see the same impedance for the lows and tweets independently as you see when they are strapped.
Wayne A. Pflughaupt
Each drive unit of a speaker is driven by a separate amp channel, so a pair of two-way speakers needs two stereo amps, and two runs of cable to each speaker. See biwiring.
If I connect both sides of a 200W/channel amp to a speaker, it now gets 400W. I will believe that until someone can tell me where the second 200W vanished to.It’s academic, really. For instance, if a speaker is rated for 200 watts, you don’t really gain anything by feeding it 400 watts via biamping.
It seems senseless to biamp using two channels of the same amp unless you are running out of power. Typically this is not the case.
Aside from that, the only good reason I can see for biamping: If you auditioned two amplifiers and decided “I like the way the mids sound with this one, but I like the way the highs sound with that one,” then passive biamping might give you the best of both.
But for the most part I can’t see any advantage of biamping using identical amps.
Wayne A. Pflughaupt
But for the most part I can’t see any advantage of biamping using identical amps.Or, even worse, consider biamping using a single 5-channel amplifier that has only one or two transformers. If the two channels you connect to the speaker both come from the same internal supply of power inside the amp then using both of the channels gives you no more reserve power than using a single channel.
--Steve
