BFD with a dipole subwoofer
Discussion in 'Archived Threads 2001-2004' started by Travis G, Oct 24, 2002.
  1. Travis G
    Travis G Stunt Coordinator
    Jan 6, 2002
    94
    As I understand it BFD automatically adjusts for a flat response when you have a calibrated mike hooked up to it and feed a little pink noise into the room. I also understand it has an adjustable subsonic filter. Has anyone here tried using it with a dipole subwoofer to get the 6dB/octave boost?
    Travis
  2. ThomasW
    ThomasW Cinematographer
    Nov 6, 1999
    2,282
    No the DSP1124P doesn't have those functions. It has an 'Auto' function for supressing feedback. Also there is no subsonic filter, no mic input, nor are there 6db/octave slopes. This info is available in the downloadable manual
    The 'Auto Q' functions you describe are a part of the of the Behringer Ultra-Curve Pro DSP8024 ..... and my understanding is that unfortunately it isn't all that accurate.
  3. Stephen Dodds
    Stephen Dodds Second Unit
    Aug 29, 1998
    354
    It should, however, be possible to get a reasonable approximation of the 6dB boost by manually setting filter points and adjusting the gain and Q of the filter.
    Check any of Anthony Gomez' posts and download his BFD program. It'll show you graphically what the filters do.
    Steve
