BFD vs. ICBM (1 Viewer)
LorenzoD
Provided I am not mistaken, and that these two devices serve the same purposes in HT (taming your bass response), which one would you recommend? And why?
ColinM
I believe they are 2 different things:
BFD = Parametric EQ
ICBM = Line level bass management
ColinM
Yes, you could.
ICBM's are for 6 channel bass management for SACD / DVD audio, I believe. This is a result of early SACD and DVD-A players lacking any bass management at all.
The sub line would run through the BFD for bass eq, although you could use EQ on all channels if you wish.
John Kotches
Exactly correct.
The typical use for the Behringer device is to prevent microphone feedback in a prosound environment, although it also finds use in the consumer arena as an inexpensive parametric EQ.
Similar Threads
vasyear
