BFD problem
Discussion in 'Archived Threads 2001-2004' started by kevitra, Jan 27, 2003.
  1. kevitra
    kevitra Second Unit
    Apr 24, 2002
    364
    I just purchased a BFD from my SVS 25-31. I bought 2 of the radioshack 1/4" phono to female RCA connectors.
    I was getting no input to the BFD, so I started to unplug the input connector. Then the lights turned on. I can only get a signal if the plug is 1/2 way in.
    It does this on both channels.
    I have the buttons on the back pushed 'in' for home use. I also held in the in/out button so it is flashing. When the plug is 1/2 in I hear the sub.
    Did I buy the wrong input plugs, or is my BFD defective?
  2. PaulT
    PaulT Supporting Actor
    Oct 28, 2002
    932
  3. kevitra
    kevitra Second Unit
    Apr 24, 2002
    364
    They look like the first one, but I'm not 100% sure. I'll check when I get home. Maybe the RS employee gave me the wrong ones. Hopefully that is it.
  4. kevitra
    kevitra Second Unit
    Apr 24, 2002
    364
    EDIT: I just looked more closely at the Radioshack site. The correct plugs say "Pack of 2". Mine were single. I most likely have the wrong ones.
    Thanks for the help..
  5. PaulT
    Oct 28, 2002
    932
    Check the tip of the adapter when you get home. If it has 2 black rings (isolators) near the tip then it is the stereo plug and you have the wrong units.
    Hope that works out for you.
