BFD or traditional parametric for sub woofer calibration
Discussion in 'Archived Threads 2001-2004' started by Martice, Nov 21, 2001.
  1. Martice
    Martice Screenwriter
    Jan 20, 2001
    1,077
    While considering which parametric EQ to purchase, I started to wonder since my only use for the BFD is to use it for a parametric EQ for my sub is it over kill?
    What are the pros and cons to using a traditional parametric as opposed to a BFD?
  2. Wayne A. Pflughaupt
    Aug 5, 1999
    6,111
    36
    6,610
    Katy, TX
    Wayne
    The pro: It’s hard to beat the BFD in terms of bang for the buck. You can usually get one brand new cheaper than a good analog (i.e., “traditional”) parametric EQ used.
    The con: Because it is digital, the BFD has a much steeper learning curve than an analog parametric.
    Either way, it is not overkill to get a parametric EQ (either kind) for your sub, Martice. It will deliver amazing improvements.
    Wayne A. Pflughaupt
