Shawn Fogg
- Oct 5, 2001
Anybody use the Behringer MIDI software to control their BFD?
I was playing around with the software and my 1124 tonight. I get the two talking to each other and I can adjust the filters using the software and hear the changes being made but I can't figure out how to save the filters in the BFD. Anybody know? I've tried the options on the 6 pages of midi setup controls but they don't help.
I can say adjust Bank 4 L Filter 1 to be 31hz 20/60 bandwidth -6db and hear/measure the change but if I use the front panel to try to confirm the filter settings it is nothing like that setting.
Changing banks then going back to 4 and the audible/measurable changes are lost and the unit is doing what the front panel says. It is *much* easier to adjust the BFD though software but if the settings won't stick it isn't much use.
Shawn
Shawn
