BFD filter help
Discussion in 'Home Theater Projects' started by Bob Bartlett, Aug 27, 2003.
  1. Bob Bartlett
    Bob Bartlett Stunt Coordinator
    Jun 28, 2001
    209
    Here are my numbers:
    Freq Raw Comp
    16 75 86.5
    18 72 80.0
    20 75 82.5
    22 84 90.5
    25 84 89.0
    28 78.5 82.5
    31.5 80.5 83.5
    36 91.5 94.0
    40 97 99.5
    45 102.5 104.5
    50 108 109.5
    56 83 84.5
    63 104 105.5
    71 89 90.5
    80 94 95.5
    89 96 97.5
    100 90 92
    As you can see I have several peaks and dips. Where should I begin? I tried to make it flat but ended up needing more than 12 filters.
  2. ThomasW
    ThomasW Cinematographer
    Nov 6, 1999
    2,282
    You start using cut to pull down as many of the peaks as possible. Only use boost at the very end of the EQ process to fine tune your curve. Use very small amounts of boost if possible
    Follow the 'how-to' instructions from Sonnie Parker's website
    SnapBug BFD Site
  3. Wayne A. Pflughaupt
    Aug 5, 1999
    6,111
    36
    6,610
    Katy, TX
    Wayne
    Bob, this is really poor response. I suggest first trying some different locations, if that’s an option, to get a better starting point.
    I suggest starting with a corner, one with the longest distance of uninterrupted wall length in both directions. Most of the time this is the best location. Also, if the sub has a variable phase control, it is usually helpful in smoothing response. If these readings were taken in a corner, then move on to some other locations.
    The readings should be taken with both sub and mains on. This will allow interactions between subs, mains and crossover to be taken into account.
    Wayne A. Pflughaupt
  4. Allen Ross
    Allen Ross Supporting Actor
    Sep 30, 2002
    819
    Bob, if i play my tempest really really loud, can you hear it way up there in Presque Isle?
    [​IMG]
  5. Bob Bartlett
    Jun 28, 2001
    209
    Wayne, the location isn't the best because it is behind the listening area under a shelf that the couch goes up against so the sub is completely hidden. I am using a 150 liter tempest. The only location change I can do is flip it so it fires toward the couch which it is doing now or towards the wall. I'll try facing it toward the wall and run some more numbers. I'll make sure to leave the mains on.
    Allen, try it and we'll see. I don't think anyone up here even knows what a tempest is.
    Here are the new numbers with the sub facing the wall.
    16 75 86.5
    18 73.5 81.5
    20 78.5 86.0
    22 87 93.5
    25 86 91.0
    28 80.5 84.5
    31.5 84 87.0
    36 94 96.5
    40 99 101.5
    45 104 106.0
    50 109.5 111.0
    56 93 94.5
    63 104 105.5
    71 93 94.5
    80 93.5 95.0
    89 99 100.5
    100 91 93
    Comparing the two graphs using Sonnie's excel program this look to be better. I figure anything is better than what I have.
  6. Rich X
    Rich X Stunt Coordinator
    Jun 18, 2002
    115
    Bob,
    Thanks for starting this thread. I'm about to start setting up a BFD for a dual Tumult system as well. I'm very interested in how you work this out. Please keep posting your progress.
  7. Wayne A. Pflughaupt
    Aug 5, 1999
    6,111
    36
    6,610
    Katy, TX
    Wayne
    Bob,
    Try these filters. I’m going to give bandwidth in octaves – you’ll have to translate that to “BFD-speak” – i.e., 1/3-octave = 20/60.
    • Center frequency 89Hz, BW 1/6-octave, cut 6dB.
    • Center frequency 63Hz, BW a little less than 1/6-octave (like maybe 1/8, if you can do that), cut 10dB. Keep your eye here on the reading at 56Hz. It should be the same value (94dB) after you’ve applied the filter. If 56Hz drops, then reduce the bandwidth of this filter until it stays at 94dB.
    • Center frequency 45Hz, BW 1/3-octave, cut 12dB. Once again, keep your eye on 56Hz. If it drops below 94dB, then reduce the bandwidth of this filter. Note: This filter will still leave the peak at 50Hz, but it will be reduced somewhat. I’ll decide what to do about it when you post your new figures.
    • Center frequency 28Hz, BW 1/4-octave, boost 10dB.
    Be sure and post your new readings.
    Wayne A. Pflughaupt
  8. Bob Bartlett
    Jun 28, 2001
    209
    Ok Wayne here they are:
    16 79 90.5
    18 77 85.0
    20 80 87.5
    22 90 96.5
    25 91.5 96.5
    28 89 93
    31.5 88 91.0
    36 94.5 97
    40 96 98.5
    45 93 95
    50 105 106.5
    56 91.5 93
    63 91 92.5
    71 88.5 90.0
    80 88.5 90.0
    89 92 93.5
    100 89.5 91.5
    Here are the filters I ended up with:
    28Hz BW 15/60 +10 Boost
    45Hz BW 8/60 -12 Cut
    63Hz BW 4/60 -10 Cut
    89Hz BW 10/60 -6 Cut
    I did have to keep cutting the bandwith on the 45 and 63 filters, but now I see what you are trying to go for. I'll keep experimenting until you give some more suggestions.
    Thanks.
    Bob
  9. Bob Bartlett
    Jun 28, 2001
    209
    After playing around some more here's what I came up with:
    16 78.5 90.0
    18 77 85.0
    20 83 90.5
    22 87.5 94.0
    25 88.5 93.5
    28 87 91.0
    31.5 88 91.0
    36 92 94.5
    40 92 94.5
    45 90 92.0
    50 93 94.5
    56 89.5 91.0
    63 92 93.5
    71 89 90.5
    80 91.5 93.0
    89 92 93.5
    100 90.5 92.5
    Not to shabby. I ended up using 8 filters:
    20Hz 6/60 +3 Gain
    23Hz 4/60 -8 cut
    28.9Hz 15/60 +10
    38Hz 5/60 -5
    45Hz 8/60 -12
    50Hz 4/60 -14
    63Hz 4/60 -8
    89Hz 4/60 -6
    Haven't had a chance to listen yet.
    Bob
  10. Jacques C
    Jacques C Stunt Coordinator
    Nov 28, 2001
    84
  11. Wayne A. Pflughaupt
    Aug 5, 1999
    6,111
    36
    6,610
    Katy, TX
    Wayne
    That’s certainly a dramatic improvement, Bob.
    Response is pretty flat now – perhaps too flat. I suggest playing test tones at 100Hz and 36Hz. They should subjectively sound like they are at the same level (although not necessarily measure the same).
    If you find that 36Hz sounds weaker, you are going to find that your bass does not sound flat, even though it measures flat. If this is the case you’ll probably want to dial in a house curve, using a shelving filter.
    You can find out how to effect a shelving filter here.
    Other information on house curve here and here.
    Wayne A. Pflughaupt
  12. Bob Bartlett
    Jun 28, 2001
    209
    Thanks Wayne I'll check it out. I will say that is sounds much better. All the boominess is gone and I don't have to run it hot like I used to to get the same effect. Thanks for getting me started in the right direction.
    Bob
