BFD experts- can I do this ?
Discussion in 'Speakers & Subwoofers' started by Brian Fellmeth, Jul 14, 2003.
  1. Brian Fellmeth
    Jul 30, 2000
    789
    Situation is that I have a 3 way stereo active line level crossover that does not sum the low band for a mono sub. I could try using a Y for the low outs and feed that summed signal to the BFD then to the sub amp, but I suspect that is a bad idea without a buffer circuit. Could I feed both channels to the BFD, link the filters, then "Y" the BFD outputs together into one for the sub amp ?
  2. MingL
    MingL Stunt Coordinator
    Mar 26, 2003
    214
    If I were in your shoes and have one sub, I'd use both channels of the BFD, link the 2 BFD's channels as a stereo pair and Y-sum them at the outs of the BFD.
    Using 2 independant stereo bfd channels to go into one sub can be pretty messy. We could change one channel, but the other unchanged channel may have unpredictable and perhaps irritating inconsistencies while correct room modes.
    Just my thoughts.
  3. Greg Bright
    Greg Bright Second Unit
    Feb 24, 2000
    266
    2
    110
    Gregory Bright
    Brian,
    I agree with Ming. Coupling the two BFD channels and Y-ing the outputs seems the most logical solution.
    Greg
  4. Michael R Price
    Michael R Price Screenwriter
    Jul 22, 2001
    1,591
    It may be almost as simple to make a buffer... any old opamp will do.
