Bettercables Silver Serpent Reference component video cable 3 meter
Discussion in 'Hardware Classifieds' started by Omar Torres, Apr 11, 2006.
  1. Omar Torres
    Omar Torres Stunt Coordinator
    Aug 22, 2004
    134
    I moved to HDMI so my beloved 3 meter bettercables Reference Component Video cable is up for grabs. I paid about $200.00 for it and am asking $100.00 OBO.
    Detailed Description
    Why our Component Video Cable is Better
    Award-winning - 2004 & 2005 Perfect Vision Magazine's Editor's Choice.
    Risk-free Money-Back Guarantee.
    Exclusively manufactured to BetterCables exacting specifications. They are not the same as similar looking, lesser cables.
    Instantly improves your home theater experience.
    Supports all HDTV formats (1080p, 1080i, 720p, 480p).
    Larger conductors for guaranteed low-loss connections.
    Component Video Cable Overview
    Our NEWEST Component Video Cable. As with all of our cables, the Silver Serpent REFERENCE Component Video Cable is engineered for video excellence. This is our most popular component video cable. This is a FUTURE-PROOF, extremely high bandwidth (3.0 GHz) multi-channel cable for the most demanding situations. High-definition TV, progressive-scan DVD, plasma displays, and projectors deliver eye-popping pictures like never before.
    Component Video Cable Technical Information
    75-ohm (+ or - 1.5 ohm) - tightest tolerance in the industry.
    Solid-core silver-coated conductors.
    500% larger conductor than our previous standard component video cable.
    Swept-tested over 3 Ghz bandwidth.
    Low 16.2 pF/ft capacitance.
    CMR rated for in-wall use.
    Gold-plated corrosion-resistant 75-ohm RCAs or BNC connectors.
    Nitrogen-injected HDPE dielectric insulation.
    Shielded with combination 100% foil and braided shield to protect against RFI and EMI.
    Installations that use component video require special parameters in the cable design. Chief among them is TIMING. Since the signal is split into 3-channels (a B&W signal and two color difference signals) and then reassembled, the signals must arrive at the same time at the destination. The more the timing variance, the less detail can be resolved in the resulting picture. BetterCables Silver Serpent Component Video design guarantees a maximum of 2.5 nanoseconds per 100 ft. This is ten times better than the broadcast maximum of 40 nanoseconds.
    "We found the Silver Serpent to perform superbly in our video setup." (John E. Johnson, Jr. - Editor, Secrets of Home Theater and High Fidelity)
    The combination of timing, low-attenuation, low-SRL makes this a world-class component video cable with no equal at ANY PRICE.
    [​IMG]
  2. Omar Torres
    Aug 22, 2004
    134
    Sold
