Better place than Dell to buy pre-built computers?
Discussion in 'Computers' started by Marty Christion, Mar 15, 2004.
  1. Marty Christion
    Marty Christion Stunt Coordinator
    Oct 3, 2001
    229
    I'm looking for a good place online where I can pick the parts I want in a computer, and they put it together and ship it to me. Are there stores like this? I don't want a Dell or Compaq pre-built one, and I'll install all the software myself. I just don't have the time to put the pieces together like I used to.
    Any recommendations?
  2. Mike Fassler
    Mike Fassler Supporting Actor
    Jan 17, 2004
    523
    heh what is the system gonna be used for first off?
  3. SethH
    SethH Cinematographer
    Dec 17, 2003
    2,867
    Here's one. I have a friend who has purchased several computers through this site and been very pleased. I'm sure there are others as well.
    http://www.compucheap.com/
  4. Vince Maskeeper
    Vince Maskeeper Producer
    Jan 18, 1999
    6,499
    The only custom house i've ever used that is worth a damn is monarch.
    But at dell's prices, unless you have VERY specific hardware needs, you will save money with dell.
    -V
  5. WayneO
    WayneO Supporting Actor
    Nov 10, 2003
    625
    http://www.buyabs.com/
    ABS is a well known and award winning company worth your business. You'll get brand name parts, not proprietary ones. Dell can make em a little cheaper for a full package, but the performance of a Dell to similar equiped custom built machines is always worse.
  6. Vince Maskeeper
    Jan 18, 1999
    6,499
    Like which?
  7. WayneO
    Nov 10, 2003
    625
    Motherboards, PSU's, Case, Cooling setup.
  8. Keith Mickunas
    Keith Mickunas Cinematographer
    Dec 15, 1998
    2,041
    I have to agree wtih this. If you are looking for a basic system or low end server and aren't too concerned about upgradability, Dell is a good choice. If you keep an eye on fatwallet.com you can find some pretty good deals for dells.
    mwave.com, which is a pretty reputable online computer store has prebuilt and barebones systems. They have good prices for components, so I imagine their PCs are competitively priced. I've bought a lot from them over the years and have been very satisfied.
  9. ChadLB
    ChadLB Screenwriter
    May 5, 2002
    1,523
    I just bought one thru www.americancomputech.com ....can select what you want....decent prices. I didn't need everything so I just bought what I needede.
  10. Chris Britton
    Chris Britton Auditioning
    Jun 24, 1999
    14
    I purchased a computer from Cyberpower for my wife and have had no issues with it or them. Was able to choose each an every component individually. For what I wanted, a tricked out AMD 3000+ with 1 GB ram and SerialATA, their price came in slightly lower than Monarch. They are at:
    h t t p://w w w .cyberpowersystem.com/
    I would have gone with Monarch (since they are local to me) if they had accepted orders over the web or by phone for local pickup. However they seemed tough to deal with and I didn't want the hassle of fighting traffic to get across the Metro Atlanta area twice to order and pick it up. If you are having it shipped it may not be an issue for you.
    Just be sure not to go with Michael's Computers. If you want to know why just take a look at:
    h t t p:/ / w w w .tomshardware.com/column/20040317/index.html
    Sorry I cannot hyperlink the above. Despite being a memeber for almost five years, I don't post much and haven't achieved the requisite 15 posts to be able to do that [​IMG]
  11. Vince Maskeeper
    Jan 18, 1999
    6,499
    Or better yet, HTF Forum partner GOTAPEX.com
    -V
  12. Rob Landolfi
    Rob Landolfi Stunt Coordinator
    Feb 26, 2002
    182
    I'll second the recommendation for ABS. They'll let you do nearly any customizing you'd like, and I've found their customer service to be outstanding. I found that it was nice to get the case, OS and original hard drive from them and add in my own extra optical drives/hard disks as needed.
    I had a problem that their phone tech diagnosed as a bad mobo, and they sent me both a mobo and a replacement CPU chip (2.8 GHZ) as they figured if the mobo went bad, there was a good possibility that the CPU could be damaged as well. After I got the parts in a couple days (they're in CA, I'm in VA), I put them in and all was well. That same night, I got a call from a local repair tech that said ABS contacted them to replace my parts as 1yr onsite came with my PC purchase. I originally declined as I'd already completed the swap out, but he mentioned that it should show that the authorized tech did the repair. Plus, he needed the service call. Anyway, he came over and quickly verified everything, including adding the thermal compound for my CPU as it was my first CPU install.
    I was very happy with ABS, and will always check them out for my desktop needs. They've just begun with notebooks, and although they may not have deeply discounted value systems, I would check them out as a place to start. Good luck.
