Better Packaging for Trek Series?
Discussion in 'DVD' started by DeathStar1, Jul 11, 2003.
  1. DeathStar1
    DeathStar1 Producer
    Dec 28, 2001
    3,267
    Anyone else finding it a pain to access the TNG DVD's because of the packaging? It's a two minute manuver to get a disc out, and another two minutes to put everything back together again. Maby they can use the slim cases found on Futurama volumes for easier access?
    I havn't had the money to pick up TNG, so I don't know if this has already been done.
  2. Britton
    Britton Supporting Actor
    Jun 3, 2001
    912
    4
  3. Dan Rudolph
    Dan Rudolph Producer
    Dec 30, 2002
    4,042
    And DS9 comes in much more convenient cases.
  4. Scott Merryfield
    Dec 16, 1998
    12,070
    927
    I converted all seven seasons of TNG to 7-disc alpha cases and Ric Easton's customized cover art. Ric did a fantastic job on the covers. I found the original packaging as cumbersome as you, Neil.
    Ric also created custom covers for TOS. Using 5-disc alpha cases, you can some shelf space over the original packaging of single-disc cases.
  5. Jeff Kleist
    Dec 4, 1999
    11,267
  6. Dan Rudolph
    Dec 30, 2002
    4,042
  7. Ric Easton
    Ric Easton Cinematographer
    Feb 6, 2001
    2,822
    86
    I always knew Jeff was talented!
    Ric
  8. Jeff_HR
    Jeff_HR Producer
    Jun 15, 2001
    3,594
  9. Jeff Kleist
    Dec 4, 1999
    11,267
    good one Dan [​IMG]
  10. Jason Seaver
    Jason Seaver Lead Actor
    Jun 30, 1997
    9,306
  11. Jeff_HR
    Jeff_HR Producer
    Jun 15, 2001
    3,594
  12. Greg_S_H
    Greg_S_H Executive Producer
    May 9, 2001
    15,452
    297
    North Texas
    Greg
    I love the DS9 cases. As for the TNG cases, you might consider keeping some spare jewel cases around for when you are watching the series in order. Keep the discs in the easy-to-open jewels until you're done, and then put them back in the box.
  13. Frank Anderson
    Frank Anderson Cinematographer
    Jun 7, 1999
    2,667
  14. Jeff Kleist
    Dec 4, 1999
    11,267
  15. Kai Zas
    Kai Zas Second Unit
    Jan 24, 2002
    395
    The DS9 cases may be a bit easier to work with, but the plastic outer casing isn't all that sturdy. My seasons one and two already came loose. Season 3 took a tumnle the other day, shattering the plastic inner casing of the first disc.
    I use jewelcases too when I'm watching, but I skipped this because the DS9 was so accessible. Next season I'll be using the jewelcases again, that's for sure.
